Multifunction DAQ
how can i get the highest and lowest data readings from a large set of readings?
(3,061 Views)
If the data is in an array, use the Array Max and Min function.
(3,059 Views)
i tried that but it just spits out the last number of the readings .....and its not an array it just a continuous stream of pressure readings but i dont know how to tell labview to pick out the largest and lowest and print it to the front panel.
(3,056 Views)
Hi Veni,
As I understand you, you get continuous scalar values (one number at a time - not an array) and want to keep the minimum and maximum value since the application started. There are different ways to do this but I will show you the easiest way, that DOESN'T involve appending the data to a continuously growing array:
Please try this out and let me know if it's not what you wanted, thanks.
Have Fun!
Message Edited by Philip C. on 09-22-2005 12:26 AM
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(3,046 Views)
