Multifunction DAQ
help: trigger configuration
hi the world
                *1
                *2
                *3
a falling body will pass through the three points noted above
each of the points is attatched with a sensor
the first two together measure speed [S/(t1-t2)]and the last one measures acceleration
the ideal is to start daq when the falling body pass point 1
and then stops at point 2 , while triggering  the acceleration  daq at point 3
can i make all these configurations in MAX ?
i've tried a few times , making two analogue triggers for mounting and falling edge respectively
but MAX complains that i can't have two analogue  triggers in the same time ?
what's the problem here ?
what else should i do ?
thanks in advance
(3,339 Views)
Which board do you use and the associated driver (daq trad or daqmx)? Will you use a NI programmation environment after or not?
Regards
David D.
Application Engineer
NI France
(3,320 Views)
thanks for the reply
well i'm using labview 7.1 with ni-daqmx 7.3 and max
i've created three measurements in one task
when i configure the triggering conditions for them in max
i found that the three must share the same timing and so the same trigger
anyway i think ive overcome the trigger problem but some other new ones come up and make my final measurement results not so satisfying.
i'll write a new article later to present the system(in fact a very basic one for most people)
u know how a layman can make some uncontious mistakes
thanks again
(3,317 Views)
