Multifunction DAQ
help on AT-MIO-16DE-10 device driver and time out error
I recently moved one NI AT-MIO-16DE-10 card from an old unstable computer to a newer and faster computer with windows xp operation system and labview 6.1. I kept the labview and max settings the same. However, in new computer, I saw two  NI AT-MIO-16DE-10 devices showed up in windows xp device manager although there is only one card. One of them cannot be started. The other one appears to be fine. In the MAX, I can still communicate with the board. I'm wondering if there is anything wrong?
The board is used as a communication card to a SCXI-1001 chassis. We have 1124, 1100 and 1163R modules on it. When I'm running the same old labVIEW program, I kept getting this error message on analog input "NI-DAQ VI: The operation could not complete within the time limit" with error code 10800. I'm wondering if anyone could help me identify this problem.
Thanks.
(2,835 Views)
Hello Fallen,
If you are using NI-DAQ 7.0 or 7.1, you should check out this link. To upgrade your version of NI-DAQ, visit this Traditional NI-DAQ page.
Jeff L.
(2,810 Views)
