Multifunction DAQ
gnu(MinGW) C++ programming question
Is it possible to program an PCI-MIO-16E-1 in MinGW C++ with the NI-DAQ 7.2 installed (in Windows 2000). If so were do I find a copy of the NI Functions in the API? I would need to know what functions are available and there syntax/usage. Thanks for any help
(2,771 Views)
MinGW is not a supported compiler for NI-DAQ. With that said, you can use this compiler as long as you are able to interface with nidaq32.dll. All of the Traditional DAQ functions reside in this dll.
Let us know if you have questions!
Justin T.
(2,771 Views)
