Multifunction DAQ
generate waveform using cvi/labwindows
AOGenerateWaveform function - How do you create a string for AOwaveform ?
(2,926 Views)
Bill
If you need to generate a square or sine wave you can use the functions SinePattern or SquareWave. If you need to specify your own pattern, you will need to define an array with the different voltages to output.
Here is a program that may help, it has code in it that will generate 7 different types of signals, it will show you how to use both functions above as well as a few others.
Brian
(2,927 Views)
