Multifunction DAQ
generate limit waveforms (envelope) from master waveform
I want to read in a waveform and then generate a upper and lower limit waveform such as according the attached picture.
is there a function in lab view available which does the calculation of the limit functions for all possile waveforms (sine, rectangle...etc.. or does somone have programmed this and can give me the code.
It would be also much helfull if someone has this in the C (Lab Windows)
regards samuel
Message 1 of 1
(2,775 Views)
