Multifunction DAQ
frequency response
Hello
I want to calculate the frequency response of a real system, a RC filter.
I use the NI example "frequency_response_(step_response_method).vi", (http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E6EF56A4E034080020E74861)
in which I generate a slow square wave,1 kHz, with my generator. But the scope don't show me the good frequency reponse of my RC filter.
The problem is that I don't have the approprite Scope-card. In fact I have the PXI-5122 .
Could you tell what I must change that this VI correspond with my card.
Nathalie
(3,116 Views)
Hello Nathalie,
You can use the example "Frequency Response (step response method)" that you can found on NI Web site :
But, you should just do some modification because NI-5122 uses NI-DAQmx and not Traditionnal DAQ :
*** In the VI front panel, in the "resource name" command, type the name of the device (MAX name) and not DAQ::... (please see the help of the function "niScope Initialize")
*** In the diagram, you will see that the example uses digital trigger. So you need to use the connector "AUX I/O".
This is a 9-pin mini-circular DIN connector Provides access to the external digital trigger lines PFI 0 and PFI 1 (with optional cable)
Please see the user manual in the link below :
http://digital.ni.com/manuals.nsf/websearch/998C51E969F4900486256D9F007103F2
I test the program with PXI-5122 and it works well.
Sanaa T
National Instruments France
Sanaa T.
(3,081 Views)
