Multifunction DAQ
fc10 and DAQmx801f0.iso
I'v tested NIKAL-1.9 and DAQmx801f0.iso on fc10. Drivers and example code compile. Drivers get loaded nicely, but ...
nilsdev reports NOTHING. Has anyone else success with these components? Any comments much appreciated!
Best Regards
Leif Adelöw
lspci reports:
02:08.0 Class ff00: National Instruments PCI-6602 (rev 01)
        Flags: bus master, medium devsel, latency 16, IRQ 17
        Memory at fe1ff000 (32-bit, non-prefetchable) [size=4K]
        Memory at fe1fc000 (32-bit, non-prefetchable) [size=8K]
        Kernel driver in use: ni_660x
        Kernel modules: ni_660x
lsmod |grep ni reports:
nimru2k               453588  1
nimxpk                 38520  0
nipxirmk              124756  1
nidimk                345632  5 nimru2k,nipxirmk
nimsdrk               295232  0
nidmxfk               485552  1 nimsdrk
nimxdfk               528384  5 nimru2k,nimsdrk,nidmxfk
nimstsk               101440  2 nimsdrk,nidmxfk
nimdbgk               400924  7 nimru2k,nimsdrk,nidmxfk,nimxdfk,nimstsk
niorbk                 98004  8 nimru2k,nipxirmk,nidimk,nimsdrk,nidmxfk,nimxdfk,nimstsk,nimdbgk
nipalk               1215376  15 NiViPciK,nimru2k,nimxpk,nipxirmk,nidimk,nimsdrk,nidmxfk,nimxdfk,nimstsk,nimdbgk,niorbk
nikal                  45460  5 nipalk
ni_660x                17664  0
ni_tiocmd               9984  1 ni_660x
mite                   13316  2 ni_660x,ni_tiocmd
comedi                 35152  3 ni_660x,ni_tiocmd,mite
ni_tio                 16512  2 ni_660x,ni_tiocmd
OS reports:
Aug  7 15:27:23 strandburner kernel: nikal: module license 'Copyright (c) 2002-2008 National Instruments Corporation.  All Rights Reserved.  Any and all use of the copyrighted materials is su
bject to the then current terms and conditions of the applicable license agreement, which can be found at <http://www.ni.com/linux/>.' taints kernel.
Aug  7 15:27:23 strandburner kernel: Symbol init_mm is marked as UNUSED, however this module is using it.
Aug  7 15:27:23 strandburner kernel: This symbol will go away in the future.
Aug  7 15:27:23 strandburner kernel: Please evalute if this is the right api to use and if it really is, submit a report the linux kernel mailinglist together with submitting your code for in
clusion.
(3,804 Views)
Accepted by topic author woleda
woleda wrote:
lspci reports:
ni_660x                17664  0
You also have the Comedi drivers installed and they are binding to the device.  You can only have one driver bind to a device at a time so NI-DAQmx will not find the device.
Shawn Bohrer
Use NI products on Linux? Come join the NI Linux Users Community
(3,795 Views)
Shawn,
Thanks a bunch! I'm sure this will save some time for other forum members as well. Now I can report on success using  fedora 10 with NIKAL-1.9 and DAQmx801f0.iso without any patches (or fuss)
kernel  2.6.27.5-117.fc10.i686 #1 SMP
Best Regards
Leif Adelow
(3,788 Views)
