Multifunction DAQ
extracting data from 2 bluetooth devices simultaneously
    Hello guys..
Im using labview since 6months. Presently Im working on interaction of Labview with bluetooth devices. Can you guys help me out in extracting the (ASCII) data from two bluetooth devices simultaneously and displaying them as graphs. (I want to convert the ASCII data from both the devices into general format and plot a graph Vs time stamps).
Thanks in advance
Navs
Telecommunications Engg
NE
(2,938 Views)
Hi nitu,
I recommend that you check out the example that comes with LabVIEW. If you do a search in the example finder for bluetooth, one of the results is "Simple Bluetooth Client". This example is doing very close to what you are trying to do (basically, they use a Type Cast function to convert the string returned from bluetooth read to a numeric).
That should get you started!
-Sam F, DAQ Marketing Manager
(2,906 Views)
