Multifunction DAQ
error 50103
I am new at using LABVIEW and I was attempting to create a PID controller to control a DC brush motor and a sensor to fire an air cannon.  I have two separate analog inputs and I need two outputs, one to cause the cannon to sweep and the other to output if the sensor is tripped.  I created each .vi indivually and each worked, but when I attempted to place them in the same .vi error-50103 occurred. Any suggestions on how to create a .vi that allows multiple inputs and outputs?
Andrew
(3,319 Views)
Have a look at this. I think your issue sounds similar to case 6:
Causes of NI-DAQmx Error -50103 "The Specified Resource is Reserved"
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,316 Views)
