Multifunction DAQ
error-10608
I had been running an executable LabView program on this computer, always it works fine.  Now an error 10608 appears with AI Control. Also there is a message, that basic address is not known and no transmission takes place. I use PCI-6111 and BNC-2110.  On other PC the BNC works. I'm newbie in LabView. What can I do? Please help.
J.S.
(3,326 Views)
Hello J.S.
Could it be, that you had a test panel in MAX opened during your application tried to use the card?
If not, could you post your code, to see how you do the analog measurement?
Best regards
D. Ackermann
National Instruments Germany
(3,303 Views)
I opened PC and chanced the PCI slot, now it works.
Thanks for help.
J.S.
(3,290 Views)
