Multifunction DAQ
digital triggering
By using pulse train during raiging edge, by digital triggering i have to write to digital port and during lowering edge, by analog triggering i have to aquire the data. how i can achieve with the PCi6036E and DIO-31HS?
(2,624 Views)
Greetings,
I am not sure that I totally understand your application. Do you want to output a digital pattern with your 32HS on the rising-edge of a digital trigger and then acquire data with your 6036E on the falling edge of that same trigger?
Let me know if this is correct or not.
Spencer S.
(2,624 Views)
