Multifunction DAQ
digital trigger
I am using a PCI 6024E data acquisition card on my damper test bench.
I acquire a waveform with the fonction AIAcquireTriggeredWaveforms (1, "0,1", 5*Pts_Cycle, freq_ech, 10.0, -10.0,
            &scanrate, DIGITAL_TRIGGER_A,
            POSITIVE_SLOPE, 0.0, "", 0, -1,
            GROUP_BY_SCAN, wave);
I create a trigger with an ampli op AD790JN, the out put is a 0-5V TTL output but the acquisition does not start at all because the fonction does not see the trigger!!!
This AD790JN is command by the servo controler of the test bench.
Can you tell me what is the problem please?
Or I do you usualy create a digital trigger with an external source
Regards
Ludovic Menteur
Solution F
France
(3,157 Views)
Have you verified that your AD790JN provides a good TTL signal? If you are not sure, you can try to generate a TTL signal with your PCi 6024E device.
Have you connected the digital trigger signal to the START TRIG input?
I
Manuel R
AE dans une autre vie
(3,119 Views)
Message Edité par ManuelR le 03-06-2007 02:43 AM
Manuel R
(3,119 Views)
