Multifunction DAQ
differential mode of PXI
I'm using PXI-4461 based on Visual Basic programming. My goal is to generate
differential mode signal with 0.5v offset using the PXI-4461 and VB.
The followings are details, but I'm attaching a ppt file for better understanding of my question.
How can I shift up the negative sinewave by +1v?
The following is the VB code which is the same as the code in the attached ppt file.
Public Sub test(ByVal numSamples As Long, ByRef writeData() As Double, dataRate As Double)
     If chanDAQ.taskHandle <> 0 Then
        DAQmxErrChkMod DAQmxTaskControl(chanDAQ.taskHandle, DAQmx_Val_Task_Unreserve)
        DAQmxErrChkMod DAQmxStopTask(chanDAQ.taskHandle)
        DAQmxErrChkMod DAQmxCfgSampClkTiming(chanDAQ.taskHandle, "", dataRate, DAQmx_Val_Rising, DAQmx_Val_AcquisitionType_ContSamps, numSamples)
        DAQmxErrChkMod DAQmxWriteAnalogF64(chanDAQ.taskHandle, numSamples, False, 10#, DAQmx_Val_GroupByChannel, writeData(0), sampsPerChanWritten, ByVal 0&)
        DAQmxErrChkMod DAQmxStartTask(chanDAQ.taskHandle)
        chanDAQ.taskStarted = True
    End If
End Sub
<Description to explain the same problem descripbed in the attached ppt file.>
PXI-4461 is connected to an oscilloscope with BNC cable. 4461 uses the differencial mode (NOT pseudo-differential mode)
due to some reason. The positive signal from 4461 (i.e. the center core of BNC) is connected
to channel 1 of the oscilloscope, and the negative signal (i.e. the shield of BNC) is connected to
channel 2.
Then A sinewave which has the range from 0 to 2v and 1v offset, was generated in VB program.
Then it was applied to an oscilloscope. The channel 1 of oscilloscope showed a sinewave which has
the range from 0 to 1v with 0.5v offset, and the channel 2 showed a sine which has the range
from -1v to 0v with -0.5v offset.
For my application, the channel 1 is ok,  but channel 2 should be shift up by 1v, basically the channel 2
should be a sine which has the range from 0v to +1v and +0.5v offset, and also its phase should lead
over 180 degree.
(3,168 Views)
Hi talking,
I have already replied to the message here.  We would appreciate it if you avoided posting the same issue on multiple threads in the future; it makes it hard to track the issue and to keep the suggestions/posts together.
Best,
Adam
Academic Product Manager
National Intruments
(3,144 Views)
