Multifunction DAQ
data saving file
  I have a USB-6008 device simple configurated to show themperature , humidity and CO2 percentage. Because I didn't work with this kind of stuff, I was wondering if someone is good enough to help me to save my measured data to a XLS file. I use this device to an incubator and I have to register 3 weeks of data.  I do not Know what function tu use for reisterinh the data to XLS file for so long. I need also with autosave in case the powerline goes dead. Please help.
   Thank you all.
(3,193 Views)
First of all post this question in LabVIEW Forum.
If you want to export your data to XLS then use write to spreadsheet file.vi located at programming>>File IO,
it is the easiest way.
If you can then you can also use the activex component. to write it to excel.
Suggestion : use build array vi rather than insert into array.
Shrek
(3,182 Views)
