Multifunction DAQ
data acquisition
Either at the end of the iteration or at the beginning of the iteration, put a property of for the Waveform chart, Set its property as>>Histroy data and wire an empty array to it
See attached VI
Message 11 of 20
(2,356 Views)
Thank you so much.! But would you please give me an image instead of vi file? I can't open it because of version problem. Thanks!
Message 12 of 20
(2,349 Views)
Hi kgy,
I figured I just open the VI and give you a snapshot of the block diagram.
Message Edited by S_Hong on 08-28-2008 04:05 PM
S_Hong
Message 13 of 20
(2,337 Views)
Thanks S_Hong Smiley Happy
Message 14 of 20
(2,324 Views)
Thanks a lot, S-Hong!
Message 15 of 20
(2,319 Views)
oh, I still have problem wiring the array with the history properties. Please see attachment. How should I modify?
Message 16 of 20
(2,312 Views)
kgy,
Do not connect a dbl array
Instead, right click on the property node>> pop down menu>>create>> constant
Now, you would have wired a blank 1D array of Dynamic data
Look at attached pic
Message 17 of 20
(2,285 Views)
I think something is wrong here. I can't select creating a constant here because it is greyed out. Please check : right-click on the waveform chart to create a property node - click to select "history data"- right-click "change to write",-right-click, create-"constant"(but unfortunately it is greyed out).
For wiring it with the loop, I create another history data element, and then change it to read before wiring it with the while loop. In this case, will the waveform chart be refreshed at the beginning of the loop or at the end? What I am trying to do is to have an empty chart when starting the data collection. Then the chart displays all the data collected until stop. Please advice. Many thanks.
Message 18 of 20
(2,277 Views)
Hi kgy,
I am not exactly sure why you are unable to create a constant for your History Data. Could you try creating a control instead and see what kind of data type you get?
As for wiring the property node to the while loop, the reason we do this is to ensure that this property gets executed before entering the loop. As with any structure in LabVIEW, the loop structure will only start once all its inputs have been acquired, in this case, the error handle.
S_Hong
Message 19 of 20
(2,266 Views)
It works now! Thanks a lot!
Message 20 of 20
(2,243 Views)
