Multifunction DAQ
daqmx error code -200561--solved remove
What is this code mean?
something to do with "Attempt"?
DAQ PXI 6230
C/C++
where do I find the error codes?
I found the error code, the data I'm attempt to write is to small or to large for the range.  My range is 0 to 5.0V.  The data buffer goes from 1.0 to 5.0.  What's the problem?
The problem is not with the range, but mix up in the config vs the write commands -- not a very focused error-like windows
(4,370 Views)
Hi Mike,
Seems you were able to sovle this issue. If you have anymore question, please post back.
Ben H.
Systems Engineer
(4,345 Views)
solved it
thanks
(4,288 Views)
