Multifunction DAQ
daq ni 6009
can i able to connect hall effect sensor and MQ5,7 gas sensor with NI 6009 DAQ card?
(3,614 Views)
yes you can connect it if it is giving voltage output and it's voltages are in range with the 6009 card. you need to compare both the specs and try it out
Regards
Yaskadeva,
India AE
National Instruments, India
Yaskadeva
India AE
There are only two ways to tell somebody thanks: Kudos and Marked Solutions 😛
(3,573 Views)
thank you very much sir!!!
(3,569 Views)
