Multifunction DAQ
daq 1200 driver problem
hi there
i am installing an old version of the multifunction daq pci 1200 series on an xp system , ni daq 7.0 driver versions are not supporting it neither are they detecting it , in the manual it says that support has been removed for 1200 series , and then i tried the 6.9.1 version on 2000 by partitioning the work space and still i have a problem , is there a way i can install the device , the drivers and measurement explorer on windows xp , and if the problem still occurs on 2000 also , is there a way around .
all healthy suggestions welcomed
(2,772 Views)
What kind of problem are you seeing on Windows 2000?
You can install the NI-DAQ 6.9.3 in XP and use it to control PCI 1200. For more information on compatibility between cards and drivers please refer to the following link.
Data Acquisition (DAQ) Installation/Configuration Troubleshooter
Also, after you install the driver, the fist time you open up Measurement Explorer hit F5 to refresh and scan for DAQ cards.
Bharat Sandhu
Penny
(2,772 Views)
