Multifunction DAQ
correlation
 I would like to control in total 7 different lines, each having its own pattern. The patterns are related (correlated) among each other such that:
- in the beginning lines 2, 3 and 4 generate a rising edge
- the first falling edge of the signal in line 2 for instance triggers a falling edge in line 3.
- the falling edges of the signals in line 3 for instance triggers a pulse in line 4.
- the second rising edge of the signal in line 4 for instance triggers rising edges in line 2, and so on.
The pulses on line 2 have a order of magnitude of 100 microseconds. On lines 1, 3 and 4 the order of magnitude is 20 to 100 milliseconds. And finally on lines 5, 6 and 7 of  1 second.
Further, I would like to use the pulses on line 4 to acquire analog date of 8 channels.
I have seen the post "Multiple Pulse Trains from a Single DO module" that Matt wrote on
Thanks for any comment
Cesar
(2,971 Views)
This looks to be a duplicate thread from the post at http://forums.ni.com/t5/Multifunction-DAQ/Correlated-Multiple-Pulse-Trains-from-a-Single-DO-module/m...
Please keep issues to one thread each, and look for support from that thread moving forward. Thanks.
Timothy S.
Senior Technical Support Engineer
(2,953 Views)
