Multifunction DAQ
compact daq
Hi all,
Is there a way to draw DC power from the backplane of a Compact DAQ to feed a customize circuit?  Thanks!
Yik
(3,257 Views)
I believe you can't do this. You will need to use one the modules to draw voltage to your circuit.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,248 Views)
It is not supported and recommended to draw DC power directly from the modules.   What is the power requirement you need from the chassis?  There are many C Series Modules that may suit your application.
C Series I/O Modules for NI CompactDAQ
https://www.ni.com/en/shop/compactdaq/compactdaq-modules.html
Jordan F
(3,236 Views)
