Multifunction DAQ
combine two DAQ Assistant
I would like to ask how do I combine the two DAQ Assistant. The input (9205) and the output (9263) together.
As I have done the input that is to acquire the signal but not sure how to connect it to the output DAQ to generate the
results. If I want to make it greater than 5 it will light up the led and less than 5 it will light off the led. I have attached what I have done but the led do not seems to light up when it is more than 5. So how do I make it work?
Regards
Christopher
(3,195 Views)
Why do you have two while loops? The second loop cannot run until the first loop finishes. That's a basic fundamental of not only LabVIEW but any programming language. Simply put the code in the second loop into the first loop.
(3,192 Views)
