Multifunction DAQ
can we dynamically adjust the DAQ Range
Hi folks,
        I have a requirement where my DAQ Card range has to be dynamically adjusted so that it utilizes the complete resolution of the DAQ card. Can anybody help it out for me
(3,020 Views)
Yes.  you just have to set the channel Min and Max value properties to change ranges of the DAQmx device.
"Should be" isn't "Is" -Jay
(3,002 Views)
Just keep in mind that you can't change the input range while the task is running (although you didn't specify your hardware).
Best Regards,
John Passiak
(3,000 Views)
