Multifunction DAQ
cDAQ BlueScreen Problem after reinitialization
Hello everyone,
i am using a cDAQ System with two analog input modules and one digital input modul in combination with Visual Studio 2005 and .net 2.0. My application simply waits for a trigger event on ch0 of the digital modul and writes the data of the analog channels to a textfile.
My program is based on the two examples:
  • "ReadDigChan_ChangeDetection" with myTask.Stream.Timeout = -1;
  • "ContAcqVoltageSamples_IntClk"
and works fine so far.
In case of a communication problem i dispose both tasks (analog and digital) - just like in the examples - and reinitialize them. I tested the reinitialization procedure by disconnection the usb cable and in most of the cases the system reinitializes as expected. However, sometimes when disconnecting the usb cable a BlueScreen event occurs and the computer reboots.
This is how the reinitialization is basically done:
if (runningAnalogTask != null)
    runningAnalogTask = null;
    analogTask.Dispose();
if (runningDigTriggerTask != null)
    runningDigTriggerTask = null;
    digTriggerTask.Control(TaskAction.Abort);
    digTriggerTask.Dispose();
initAnalogMeasurement();
initTriggerInput();
Is this a known bug and is there a solution for this problem or does anybody else have simillar issues?
Here my system configuration:
  • cDAQ 9174 with
  • 2 NI 9222 Analog input modules and
  • 1 NI 9421 Digital Input modul
  • sampling rate is 125000 samples/s
  • Windows7 64Bit
  • NI-DAQ MX 9.6.1
Message 1 of 1
(3,255 Views)
