Multifunction DAQ
cDAQ-9172 not showing modules in NI MAX
I am working in Windows 7. I have a cDAQ-9172 that contains the NI 9211 module. Everything is plugged in and turned on. The driver is up to date. Attached to this post are 5 images that show the National Instrument programs downloaded on my computer. Also 1 image that shows my NI MAX where you can see the cDAQ-9172 is connected but no modules are recognized.
I have successfully had this work through virtual box on windows XP. Everything is connected the same. I think it is a software issue. Maybe something different because a switched from windows XP to windows 7? Thoughts?
Thank you!
Natalie
(2,056 Views)
Have your tried installing a later (non-Legacy) version of NI-DAQ?
I see where NI-DAQ is a traditional (Legacy) version.
(1,969 Views)
