Multifunction DAQ
basic data acquisition
I've bought a DAQ 6008 for using with LabView 7.1, Windows XP.
I'm trying to do a basic data acquisition VI so I can read an analog input. However, I'm having troubles working with the tasks.
Does anyone have a simple and ready to use VI for reading an analog input and plot it in a chart?
Thank you,
Joao
(2,909 Views)
Joao ,
There are a number of shipped examples that you can refer to for getting started with you data acquisition examples.
The examples for DAQmx Base are located at : Start >> Program Files >> National Instruments >> NI-DAQmx Base >> Examples >> LabVIEW 7.1
The other option is to upgrade to the DAQmx 7.5 driver. You can then use DAQmx VIs to program your application. You can then use the DAQmx shipped examples that are located in LabVIEW under Help >> Find Examples >> Hardware Input and Output >> DAQmx
Hope this helps.
Somendra
(2,883 Views)
