04-26-2004 01:32 AM
04-27-2004
09:26 AM
- last edited on
11-10-2025
11:34 AM
by
Content Cleaner
Albert,
It sounds like you may have a grounding issue. Is your board configured for reference single-ended (RSE) or non-reference single-ended (NRSE)? When you say "too weak", does this mean you aren't reading anything? What voltage are you expecting to read. Is the laptop plugged in when you are acquiring data? That is, does it have its own ground reference? You may want to analyze your setup as far as determining your various ground references. I would also suggest reading the following tutorial that discusses many factors that need to be taken into account when wiring signals in the field.
Tutorial
