Multifunction DAQ
autoscroll table
How ca I set a table property to autoscroll when is filled with data. I always want to see the last line from the table. The table is filled chronologically (not the last line in front).
(3,595 Views)
I'm guessing that you mean in LabVIEW since an older post of yours mentions using it. If that's the case, you can use the Index Values property of a table. You get the size of the table with the Array Size function, get the number of rows with the Index Array, subtract the number of rows that are visible in the table, and write that value to the row element of the Index Vals cluster. The row set is the cell displayed in the upper left corner of the table.
p.s. In the future, post questions like this in the LabVIEW forum since it does not pertain to DAQ.
Message Edited by Dennis Knutson on 11-14-2005 12:45 PM
(3,597 Views)
Thank you.
I manage to find a solution in the meantime.
I posted the message in DAQ by mistake. Usually my projects are related to DAQ.
(3,575 Views)
Sorry I forgot to atach the file.
(3,574 Views)
