Multifunction DAQ
anlaog stop tigger
i use 2 pci-6110 card for DAQ. The Start tigger comes over AI-0, not PFI
with
LowValue = -3;
HighValue= 3;
iStatus = Configure_HW_Analog_Trigger (iDeviceMaster,
ND_ON,LowValue,HighValue,ND_INSIDE_REGION, ND_THE_AI_CHANNEL);
Select_Signal( iDeviceMaster, ND_IN_START_TRIGGER, ND_PFI_0, ND_LOW_TO_HIGH );
Select_Signal( iDeviceMaster, ND_IN_STOP_TRIGGER, ND_PFI_0, ND_LOW_TO_HIGH);
the start trigger works properly ( from -10V to -3V)but the stop trigger(over 3V), dose not.
thanks,
HM
(2,767 Views)
Hi HM,
I don't know if it exactly fits your issue, but I have found an example in our Example code library.
Here is the link:
http://venus.ni.com/stage/we/niepd_web_display.DISPLAY_EPD4?p_guid=C30EB49AA42E6FF0E034080020E74861&p_node=%20DZ52308&p_submitted=N&p_rank=&p_answer=&p_source=Internal
If this does not help, please ask again.
regards
Peter Weber
NI Germany
(2,767 Views)
thanks for you answer, but i can not reach the link!
(2,767 Views)
Ok, then I will post the VI.
The Example uses the PFI 0-Channel, but you can change the trigger-input in the code.
I hope this helps.
regards
Peter WEber
NI Germany
(2,767 Views)
