Multifunction DAQ
analog output timed with loopback to analog input 6009
I have a question which is quite often touched on forums, helps and others, but nowhere finally solved.
My 6009 has 2 slow analog output ports, I would like to make loop with them.
start
send sinusoid n-level to analog output (in "on demand" mode)
pause 100ms
acquire signal on analog input (shorted with analog output)
back to start
I didn't find any solution how should I configure my signal express to work in generation/acquire mode. Because there is a lot of examples in labview - not in signal express.
Please send me hint.
(3,270 Views)
Hi
We have discussed this issue on private emails, so I'll just post what we came to here, so that everyone knows it for the future.
USB-6009 doesn't support hardware timed generation, so it's not possible to generate "N-samples" of a signal with it - you have generate 1 sample/iteration. See this KB: http://digital.ni.com/public.nsf/allkb/6F2C2B49A89D685C8625711D007BDD64
In order to do it you can do one of the following things:
1/ Start another application (i.e. made in LV) to keep generating samples in background
2/ Use DAQmx Generate step for 1 sample (on demand), but you need to make some logic, which would provide 1 sample of desired signal in every iteration.
Hope it helps. Let me know if you have any other questions.
Maciej Antonik
National Instruments Poland
(3,244 Views)
