Multifunction DAQ
analog output problem using USB-6009 on Linux
Hi All,
             I intend to use USB-6009 for continuous analog output generation on Linux. To this end I tried to run the example program ‘contGeneration.c’ , found in folder:
/usr/local/natinst/nidaqmxbase/examples/ao/contGeneration.c
Once I tried to run the exe, it gave me the following error message:
Daqmxbase error, specified property is not supported by the device or is not applicable by the task
I tried to change the min.max value of Analog input voltage range, or the no of samples per second, but to no avail.
Does the USB-6009 supports continuous analog output generation, and  if yes, how to proceed further ?.
Adeel
(3,713 Views)
No, the 6009 only supports on-demand analog output. Since this is software timed, the frequency of the output is going to depend on the pc, the os, and how you write your program.
(3,709 Views)
But, I think, that there is a possibility to make pauses between acquire and generation steps for specific machine and software to obtain ~expected frequency waveform.
Am I wrong?
(3,568 Views)
Hi Wojas,
          Like Dennis said, the 6009 only supports on demand  analog-output.  I think what you're looking to do it to put your on demand output inside a while loop so that it's outputing at the speed your processor will allow.  I would recommend checking out this link. This KnowledgBase addresses your issue as well.  Happy programming!
(3,540 Views)
