Multifunction DAQ
ac coupling
i have the adquisition card 6023E and i want to mesure a signal that it has an ac and dc signal. The dc signal is around -10 to 10 and the ac signal is around +-1mV. How i can remove the DC signal? i tried to put a capacitor, but which value?
thx
(2,899 Views)
Hello dav,
To block DC, you may generally place a capacitor in series with the signal and the channel input of the DAQ board. No matter what value you choose, the DC should be blocked completely. You'll have to experiment with different values to see what works best for you, but in general the relationship is as follows: The larger the capacitor, the better AC signals are passed through the capacitor. Lower frequencies need a larger capacitor than higher frequencies. The larger the value of the capacitor, the less the AC signal will be attenuated.
As a starting point, you might try a 1 uF and go from there.
Russell
http://www.ni.com/support
(2,899 Views)
ok, i know this,m but the problem is with a large capacitor the time response is slow, and i need to remove the dc signal quickly.
(2,899 Views)
