Multifunction DAQ
Windows Embedded System 7
I am trying to load Microsoft Access onto a cRIO- runnig WES7 DVD Image 1.0.1f1.  The installer for Access is giving an error: "unable to proceed.  To install and use this product you must be running Window 7 Service Pack 1 (SP1).
Has National Instrument started supply cRIOs with WES7 (SP1)?  If so is there an upgrade path for existing cRIOs?
Paul
(4,679 Views)
Accepted by topic author Paul_Knight_Lockheed_Mart
Hi Paul_Knight_Lockheed_Martin,
It appears the bigger issue here is that Microsoft Access is saying that it requires Windows 7, not WES 7. Per Microsoft's website the Office 2013 suite is supported on the following operating systems:
  • Windows 10 (32-bit or 64-bit)
  • Windows 8.1 (32-bit or 64-bit)
  • Windows 8 (32-bit or 64-bit)
  • Windows 7 (32-bit or 64-bit)
  • Windows Server 2012 R2 (64-bit)
  • Windows Server 2012 (64-bit)
  • Windows Server 2008 R2 (64-bit)
https://technet.microsoft.com/en-us/library/ee624351.aspx
Unfortunately, Windows Embedded Standard 7 is not included amongst that list.
Kevin
http://www.ni.com/support
(4,657 Views)
(4,646 Views)
