Multifunction DAQ
Windows 7 compatibility with Trad. Daq and conversion Trad. Daq to DAQmx 9.5
Hi all together,
I am trying to get old software using the traditional Daq running on windows 7 with DAQmx version 9.5.1 .
As far as I understand I need to substitute the old .vi´s by the new DAQmx vi´s. Especially I would like to substitute
Counter control.vi
Counter Get Attribute.vi
Counter Group configure.vi
Counter Set Attribute.vi
Do you know what could be the corresponding vi´s in the DAQmx version 9.5.1.? Is it necessary to reprogramm or can simply substitute the old vi´s by the new ones in my costum vi?
Thanks a lot for answers in advance!
(3,309 Views)
Unfortunately, there is no one to one correspondance between the two drivers. You need to reprogram.
(3,304 Views)
Dennis is right (as usual), but I'd add that if you understand the functional behavior you need to produce, there's a good chance you can find a DAQmx-based example that'll at least get you really close.
My foggy memory of  counter programming in trad NI-DAQ makes me suspect you might have a simple edge-counting task, possibly from a non-default input terminal.  I'm guessing that "Counter Control" is called to start the task and "Counter Get Attribute" is called to read the count.  I think I recall that "Set Attribute" was only needed for non-default stuff, like specifying a different place to look for the edges (events) to count.
Am I close?
-Kevin P
(3,293 Views)
(3,292 Views)
