04-08-2011 08:07 AM
I recently upgraded to Windows7, and I was already working on a program using a DAQPad-6020E(USB). My computer doesn't recognize the hardware and I cannot see it in MAX either. Also I cannot install Traditionnal NI-DAQ which I think is my problem...My question then is: Will I ever be able to install Traditionnal NI-DAQ on Windows7?
04-08-2011 09:04 AM
There are no plans to migrate the Traditional NI-DAQ driver to Windows 7. The Traditional NI-DAQ driver is a legacy driver and no new support is planned. The DAQPad-6020E is not supported in the NI-DAQmx driver, so you will need to stick with Windows XP and Traditional NI-DAQ.
07-12-2011 09:56 AM
How, or what is the best way, to have access to traditional DAQ software as customers migrate from older O/Ss to Windows 7?
Thank-you.
07-12-2011 11:43 AM
There is no way. Customers should have migrated to DAQmx which was introduced several years ago.
07-12-2011 12:13 PM
Thank-you for the reply.
Could you be more specific on how the mirgration would/could be done to DAQmx?
e.g. what are the software drivers and the order that they are to be loaded
07-12-2011 01:14 PM
An excellent KB article
That should help you migrate and understand the improvements that DAQmx brings to your code
07-13-2011 06:24 AM
Thank-you Jeff - much, very much appreciated
