Multifunction DAQ
When Im tryin to add phy. channel thru DAQ it says no support devices found why?
I'm trying to create a new express task through the DAQ assistant in the labview (as suggested in the labview getting started manual). But when I'm trying to add physical channels for voltage measurement through acquire signals options, it says there are no support devices found. How do I solve this problem.
(2,932 Views)
What device do you have installed in the pc? What version of DAQmx are you using and what version of LabVIEW? Is the device listed under DAQmx in MAX (Measurement & Automation Explorer)?
(2,929 Views)
