Multifunction DAQ
What update rate do I need?
I want to generate 10Hz analog signal.
What the recommended update rate and number of samples for such a signal?
(3,884 Views)
to keep shape you should use sampling at least 10 times the frequency of the signal. Means if you generate 10Hz sine wave, you need at lease 100S/s update. Higher is better. You can use 1000S/s for example. In case of how many samples you should use, then you should prepare one period of the signal. This means for 1000S/s you should prepare 100 samples representing one full period of your signal and use regeneration mode (default).
regards,
stefo
(3,870 Views)
Okey thanks but could you please explain to me how do you calculate the number of required samples if I want to generate 10Hz sine wave with update rate 1000S/s?
Yeah I know you had explained briefly in previous post but I still could not understand yet this fundamental issue.
(3,860 Views)
Accepted by topic author yusof
It is really simple arithmetic. Divide the sample rate by the frequency to get 100 samples for a single cycle.
(3,850 Views)
