Multifunction DAQ
What is the maximum guaranteed sampling rate for the pxi-6132?
The specification for the PXI-6132 states that it has an analog samplig rate "up to 2.5 MS/s".
When I set the sampling rate to 2.5 MS/s sometimes I get the error:
"NationalInstruments.DAQmx.DaqException: ADC conversion attempted before the prior conversion was complete."
The code that I am writing will be deployed across many systems.
I want to get the base time resolution on the signal I am digitizing; but, I need to do it consistently without error.
How do I avoid getting this error?
What is the maximum rate that I set the Digitizer and be assured that I will not get a digitization rate error?
(3,834 Views)
Do you get this same behavior if you sample at a slower rate, or only at that speed?  How many channels are you sampling on?
Shane C
(3,808 Views)
