Multifunction DAQ
What is Daq-mx error code -50103
I am trying to find out what error code -50103 is?
(3,632 Views)
Help>Explain Error
This is a common error. Do a search for the error code or message 'resource reserved'.
(3,629 Views)
Not common enough, I did a search and no results for that specific error.  I am guessing it is system resource issue but I am frustrated with NI and lack of clear information on error codes, it seems every time I have an error code I have to post to this forum, this is not accpetable to me, why couldn't you have just provided the info for the error code
(3,622 Views)
Search results
I've provided the info over and over again. You have created more than one task for a specific hardware resource as noted in the majority of the posts above will explain.
(3,619 Views)
Okay so I found it after dropping the minus sign
(3,614 Views)
