Multifunction DAQ
What does a 'Labview load error code 8' mean?
I've installed a PowerDAQ PD2-MF-16-400/14H board, but all the examples that came with the installation give the following error message:
Resource not found. An error occured loading VI 'PD ... VI'
LabVIEW load error code 8: Could not load VI resource.
(2,767 Views)
Greetings,
It sounds like these examples were written in a newer version of LabVIEW than you are using. I would verify, with the company that provides these VIs, that your version of LabVIEW is not older than the version in which they have been saved.
Good luck with your application.
Spencer S.
(2,767 Views)
