Multifunction DAQ
What bolt/screw must i use to mount a 9148 chassis to a panel?
Hi
I'm going to be using a 9148 Expansion Chassis for a project.  I'm having a custom subpanel made and would perfer to have the mounting location drilled and tapped so i can moun the panel to the plate.  I found mounting dimentions on the data sheet, but nothing in termins of the size of the hole available?
What screw/bolt should I plan for?
(4,330 Views)
Hi mmarmol,
The manual for the 9148 chassis recommends M4 screws in the sections on mounting the chassis (pgs. 2-6). The manual is linked below:
http://www.ni.com/pdf/manuals/375519a.pdf
Catherine B.
(4,309 Views)
there it is.  page 2.
use 2 M4 or #10 panhead screws.
missed that the first 3 times i read the thing.
(4,307 Views)
