Multifunction DAQ
Was zu tun beim / What to do when: Error -88705 occurred at Self-Test (NI-DAQmx 9.3.5 / Windows 7 32bit)
System configuration:
Windows 7 32bit
NI-DAQmx 9.3.5
 what is the solution?
(3,916 Views)
the system takes a lot of time during booting...
(3,915 Views)
the board is PCIe 6251
(3,914 Views)
what does Windows Device Manager look like?
(3,907 Views)
everything looks fine in the Device Manager (attached is a print screen of it)
(3,881 Views)
Youre device may have entered a weird state due to any number of reasons (power outage, program crash, etc)
Try resetting the device in MAX.
If that doesn't work, reboot the PC.
If that doesn't work, shutdown the PC, move the card to another PCIe slot if possible, or take it out and put it back in making sure it is seated properly.
If that doesn't work, reinstall your DAQmx driver.
If that doesn't work, send it in for an RMA.
(3,862 Views)
