Multifunction DAQ
Warning when generating and acquiring simultaneously
Hello all!
I'm having a warning while acquiring and generating simultaneously and I don't understand what is the origin of this warning.
When I acquire or generate signals independently there is no warning.
The warning code is 200015.
I already searched the forum but the threads I've found were of no help...
I attach my .vi so that you can test and see what I'm doing.
This is just an example .vi but I'm using the same principle (generating and acquiring simultaneously) in a larger application...
Any help would be greatly appreciated.
Thanks in advance.
(3,114 Views)
I tried your VI and I rearranged it a little bit. Here it works quite well...
Try this and tell me if you still have your warning.
Regards
Richard Keromen
(3,090 Views)
Thank you very much for your reply...
I'm out of the country now and I'm not able to test it.
As soon as I get back I'll try it and say what the result was.
Best regards!
(3,061 Views)
