Multifunction DAQ
Viewing data continuously in Labview
I am currently using two channels from a USB-6251 that bring in two EMG (muscle activation) voltage signals. I am trying to graph both of these and display the waveform in realtime using Labview and the DAQ assistant. The issue is that I am only able to view a very small amount of data (< 1 second). I would like to see at least 10 seconds of data.
 It is my understanding that
Time = Samples to Read / Rate
So by increasing my sampling rate or decreasing my samples to read should increase the amount of time of data that I see on the graphs. However, the lowest I can go for samples to read is 30, thus making the required sampling rate really high. So high that I had to add a delay to the VI in order to prevent CPU slowing. I am hesitant to add too much of a delay since the purpose of viewing the data in realtime is for live feedback.
Is there another way to do this I am new to labview so I am still learning all of its capabilities.
Thank you in advance for you help!
I've attached some pictures of my setup
(2,959 Views)
Your basic arithmetic is all backwards. In order to increase the time, you would decrease the sample rate or increase the number of samples. If you had a sample rate of 5000 s/sec and you requested 2500 samples, you would see .5 seconds worth of data. If you decreased the sample rate to 2500 s/sec and kept the number of samples the same, you would acquire 1 second of data. If you kept the sample rate the same and increased the number of samples to 5000, you would acquire 1 second of data. To acquire 10 seconds worth of data, instead of decreasing sample rate or increasing the number of samples, you might want to keep the old data in a shift register and just append the newly acquired data to that. You could also switch to using a chart instead of a graph. A chart keeps the old data (up to the history size you define). A graph doesn't.
(2,947 Views)
