I'm using the 6025e DAQ in order to acquire an analog video signal. The signal is very slow, and the VSync is of order of 1 second. (Each second a new frame). There is a loop which controls this routine of reading this data and then by using IMAQarraytoimage I get the picture. I want to be able to change contrast and brightness of the image on the fly, meaning that even though the new frame has not yet been updated, these features would have an immediate impact on the current picture. For this I have built an additional loop which handles event cases of contrast and brightness value change. The problem is that even thoght while I'm changing the contrast and the brightness value, I see the impact, the current frame responds well, when the new frame arrives, it uses the previous contrast/brightness settings and so it "goes back". Only on the next frame, does it use the newly set contrast/brightness.
I've attached the these 2 sections from the application for you to see.
Thank you.
