Multifunction DAQ
VB6 version of GetTerminalNameWithDevPrefix
Many of the ANSI C example programs use the function GetTerminalNameWithDevPrefix.
Has anyone ported this to VB6?  For some reason, I cannot get it to work.
Van
(3,589 Views)
You may find this in an example posted on ni.com:
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:ex,n8:3478,ssnav:dzn/...
Hope this helps!
--Michelle
(3,565 Views)
Hi Michelle,
Thanks for the link, but I looked through most of the resultant links and did not find what I was looking for.  If you know exactly which file it is in, that would be great!
Van
(3,549 Views)
Well, I thought we could find it from an example on synchronizing multiple devices but I didn't see any examples for this in VB6. I also checked the help with no luck. I'll see what I can find.
--Michelle
(3,523 Views)
Hi Van,
Here is the function as found in one of the ANSI C shipping examples (Synch AI-AO).  The DAQ calls should be similar in VB6.
Best Regards,
John Passiak
(3,508 Views)
