Multifunction DAQ
Using Python, continually sample two AI modules and apply a timestamp to the readings?
This should meet your requirement.
https://tmesystems.net/
Message 11 of 14
(1,683 Views)
You can also enable TDMS logging, which captures the t0 of the first sample. You can then browse TDMS files or read using npTDMS · PyPI.
Message 12 of 14
(1,668 Views)
Can you please show to you extract t0 (assuming that's the only one available from the log file?
 tdms_file = TdmsFile.read(os.getcwd() + '\data.tdms', raw_timestamps = True)
    for group in tdms_file.groups():
        group_name = group.name
        print(group.properties)
        for channel in group.channels():
            print(channel.properties)
The above code gives me this ouptut:
OrderedDict()
OrderedDict([('NI_Scaling_Status', 'unscaled'), ('NI_Number_Of_Scales', 2), ('NI_Scale[1]_Scale_Type', 'Linear'), ('NI_Scale[1]_Linear_Slope', 2.6226045264365987e-09), ('NI_Scale[1]_Linear_Y_Intercept', 0.0), ('NI_Scale[1]_Linear_Input_Source', 0)])
Message 13 of 14
(1,635 Views)
The t0 and dt are the metadata of the channel properties. If you open the TDMS file with Excel, you can see t0 & dt and data are on two different worksheets. For more details, NI TDMS File Format - What is a TDMS File?
I have attached an example to read the TDMS file.
Message 14 of 14
(1,591 Views)
