Multifunction DAQ
Using PWM on NI-6008
Im trying to create a vI to output a pulse with the NI-6008 device. is it even possible to do such a thing with the hardware i am trying to use. if so, how would i go about approaching the problem.
Thanks, Tim.
(3,199 Views)
Hi Tim-
It sounds like you're trying to create a PWM output on your counter with the USB-6008
The counter on the USB-6008/6009 is a simple event counter only. There are no output pins, so it won't be possible for you to perform any kind of PWM or counter output.
I hope this helps!
Thanks-
Message Edited by Tom W. on 06-23-2005 01:02 PM
Tom W
(3,181 Views)
