Multifunction DAQ
Using PFI0 to ENET9205 like digital output
I have a ENET9205 and i want to configure the PFI0 terminal like a digital output to set them to logic 0 or logic 1, for selecting two different clock source to drive the terminal PFI1.
Can it possible and what is the solution?
Thanks for the answers!!
(3,533 Views)
Hello Youl,
This is not possible. PFI lines are used in your case for triggering purposes. If you need a digital output with the NI-9205, you'll need to program it on the cRIO plateform (Using the Digital Output and PFI Lines of the NI 9205/9206 with CompactDAQ).
(3,508 Views)
Bonjour,
Merci pour la réponse et sinçères salutations!!
(3,440 Views)
