Multifunction DAQ
Using PCI-6251 with Labview 6.1
I recently purchased a PCI-6251 multifucntion DAQ board to get a higher sampling rate than my old PCI-MIO-16E-4 board.  However I have existing software that I want to run on the new board.  The board came with NI-DAQmx which will only work with Labview 7 or above.  I am currently running NI-DAQ 6.9.3 and the Measurement and Automation program does not recognize the new PCI-6251 board.  Is there anyway to get Labview 6.1/NI-DAQ 6.9.3 to recognize and configure the new board?  Or will I be forced to upgrade my Labview?
(3,115 Views)
The M-series boards (PCI-62xx are M-series) require NI-DAQmx driver. The NI-DAQmx driver requires a newer Labview. No way around it.
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(3,104 Views)
OK, thanks John.
(3,094 Views)
